1. Re: ClearScan resulting in distorted text
CtDave Oct 26, 2013 8:15 AM (in response to GeorgeNelson)
OCR "Searchable Image (Exact)" leaves the image "exactly" as-is. No tweaks.
The OCR output is not visible. The OCR output uses text rendering mode 3 (the glyphs have no stroke and no fill).
Consequently any post process visual display issues would stem from something else.
OCR "Searchable Image" does tweak the image some (e.g., deskew).
ClearScan replaces bitmaps of characters recognized with an Acrobat internal font.
If a bitmap of character is not recognized the bitmap is left as-is.
ClearScan outputs visible glyphs.
How these glyphs are rendered is a function of the display hardware and its associated software.
Be well... -
2. Re: ClearScan resulting in distorted text
Varinder.Saini Oct 29, 2013 11:11 PM (in response to GeorgeNelson)Could you please share the PDF file on which you are seeing this issue. Is it happening for that specific PDF? or is it happening for all the pdfs?
Varinder
