1. Re: Unable to sign in to CS Extension Builder
Hallgrimur Bjornsson Mar 5, 2013 8:16 AM (in response to peacea)Hi Adrian,
I will investigate and get back to you as soon as possible.
Best regards,
Hallgrimur
Product Manager - Extension Builder
2. Re: Unable to sign in to CS Extension Builder
Hallgrimur Bjornsson Mar 5, 2013 8:45 AM (in response to Hallgrimur Bjornsson)Hi again,
Can you send me your Adobe ID via private message?
Best regards,
Hallgrimur
3. Re: Unable to sign in to CS Extension Builder
Joseph Labrecque Apr 4, 2013 6:02 PM (in response to Hallgrimur Bjornsson)This same exact thing is happeing to me... can you suggest anything?
4. Re: Unable to sign in to CS Extension Builder
Hallgrimur Bjornsson Apr 4, 2013 6:05 PM (in response to Joseph Labrecque)Hi,
Thanks for the message. Please send me your Adobe ID via private message and I can check what's going on.
Best regards,
Hallgrimur
5. Re: Unable to sign in to CS Extension Builder
g_miles33 Jun 26, 2013 3:10 AM (in response to Hallgrimur Bjornsson)Hi
I have the same problem, I downloaded from the partners sites.
I did have 2.0 install in flash build 4.6 when I install.
Is there any update on this.
6. Re: Unable to sign in to CS Extension Builder
Hallgrimur Bjornsson Jun 26, 2013 3:28 AM (in response to g_miles33)Hi,
Please send your Adobe ID to me via private message.
7. Re: Unable to sign in to CS Extension Builder
PClaerhout Jul 3, 2013 11:40 AM (in response to Hallgrimur Bjornsson)Same problem here. I'll send you my Adobe ID in a private message.
pieter
8. Re: Unable to sign in to CS Extension Builder
adeschepperj2s Jul 12, 2013 2:43 AM (in response to Hallgrimur Bjornsson)HI,
I have the same problem.
"Please log in with your Adobe ID to use Adobe Extension Builder"
9. Re: Unable to sign in to CS Extension Builder
PClaerhout Jul 15, 2013 3:30 AM (in response to adeschepperj2s)Did anyone get news on this issue?
I'm still waiting for a reply...
pieter
10. Re: Unable to sign in to CS Extension Builder
Bartek Kropaczewski Jul 16, 2013 2:33 AM (in response to peacea)I have the same problem.
11. Re: Unable to sign in to CS Extension Builder
zyggymouse Jul 16, 2013 3:47 AM (in response to Hallgrimur Bjornsson)I had the same problem this morning after migrating from 2.0 to 2.1 on an existing project. As FB rebuilt the workspace, the log in screen (CSIDE1) appeared -- and kept reappearing, even after going through a pw reset back at the Adobe mother ship. I'll send you my Adobe ID, as well, via private em.
12. Re: Unable to sign in to CS Extension Builder
Toto RoToTO Jul 18, 2013 6:52 AM (in response to Hallgrimur Bjornsson)Hello,
I am encountering exaclty the same issue. This is pretty problematic.
What could / should I do to fix that?
Thomas.
13. Re: Unable to sign in to CS Extension Builder
PClaerhout Jul 18, 2013 6:54 AM (in response to Toto RoToTO)I've contacted several people at Adobe to get more info on this, but I was unable to get any answers so far :-(
pieter
14. Re: Unable to sign in to CS Extension Builder
Toto RoToTO Jul 18, 2013 7:14 AM (in response to PClaerhout)So I gues I will need to downgrade to Extension Builder 2.0 and wait for Adobe to fix this.
I hope this won't be too long otherwise it will be a major issue for me not being able to port my extensions to CC.
15. Re: Unable to sign in to CS Extension Builder
Juan_SN Jul 18, 2013 7:15 PM (in response to Toto RoToTO)Hi guys,
I am a bit confused by this thread.
The original post was posted in March, 2013, and the issue is for Eb2.0 only, because we didn't deliver EB2.1 at that time.
But it seems some of the replies are for EB2.1, saying some of you met login issue when you migrated from EB2.0 to EB2.1.
I will post a new one to get more exact information.
Juan
16. Re: Unable to sign in to CS Extension Builder
Hallgrimur Bjornsson Jul 22, 2013 1:03 PM (in response to Juan_SN)Hi all,
Thank you for your messages.
For those users that have downloaded EB 2.1 from the Partner Portal, we will be delivering a new build to it that fixes the problem you are encountering. Meanwhile you can download and use the Trial build (http://www.adobe.com/products/adobe-extension-builder.html, hit Try on the right).
Is there anyone here that is using the Store build (from here: http://www.adobe.com/uk/products/adobe-extension-builder.html) and has the same issue?
Best regards,
Hallgrimur
17. Re: Unable to sign in to CS Extension Builder
PClaerhout Aug 28, 2013 2:34 AM (in response to Hallgrimur Bjornsson)Hi Hallgrimur,
has the EB 2.1 version on the partner portal been updated in the meantime?
pieter
18. Re: Unable to sign in to CS Extension Builder
Hallgrimur Bjornsson Aug 28, 2013 2:35 AM (in response to PClaerhout)Hi Pieter,
Yes it has and should work without problems.
Best regards,
Hallgrimur
19. Re: Unable to sign in to CS Extension Builder
peacea Aug 28, 2013 2:40 AM (in response to Hallgrimur Bjornsson)Hi Halligrimur,
I am having this sign in issue with EB 2.1 from the store build (http://www.adobe.com/uk/products/adobe-extension-builder.html). Has this build also been resolved?
Adrian
20. Re: Unable to sign in to CS Extension Builder
Hallgrimur Bjornsson Aug 28, 2013 3:01 AM (in response to peacea)It should work. Did the problem reappear after having worked for some time?
21. Re: Unable to sign in to CS Extension Builder
Tady2000 Aug 28, 2013 6:54 AM (in response to Hallgrimur Bjornsson)Yes, it was working. I then installed subclipse and the sign in issue reappeared.
I've removed subclipse, and re-installed EB2.1. This has not worked.
Please advise.
Adrian
22. Re: Unable to sign in to CS Extension Builder
Hallgrimur Bjornsson Aug 28, 2013 7:02 AM (in response to Tady2000)I see...
you should be able to run any other Eclipse plugin without affecting EB 2.1.
When you uninstalled EB2.1, did you uninstall Flash Builder itself? If not, I suggest you do that, and remove any reference to it in the registry.
Before you do this, I recommend you delete a file called opm.db which is located here on a Mac: ~/Library/Application Support/Adobe/OOBE/ (please make a backup copy of the file first). Then try again.
Let me know if it works.
Best regards,
Hallgrimur
23. Re: Unable to sign in to CS Extension Builder
peacea Aug 29, 2013 6:20 AM (in response to Hallgrimur Bjornsson)I've tried deleting the opm.db file then uninstalling (without unregistering) Flash Builder, installing Flash Builder, and then installing EB 2.1.
I am still getting the sign in issue.
Please advise.
Adrian
24. Re: Unable to sign in to CS Extension Builder
Tady2000 Aug 30, 2013 6:49 AM (in response to peacea)Hi Halligrimur,
Deleting the opm.db file, uninstalling FB and then re-installing FB and EB 2.1 did not work.
Is it because I did not remove any reference to it in the registry? If so, what is the 'key' I should be looking for when removing it in RegEdit on Windows?
Adrian
25. Re: Unable to sign in to CS Extension Builder
Dhwanil_3 Sep 12, 2013 5:03 AM (in response to peacea)Hi,
I am also facing the same issue. Following are the details:
I have license version of
1.Adobe Flash Builder 4.6
2. Adobe Illustrator CS6
3. CS Extension Builder 2.0 ( monthly subscription)
I get the error when i try to run the project. It asks for the Username and Password for Adobe. Even after providing the correct credentials it gives the error "Please login with Adobe ID to use Adobe CS Extension Builder".
I have tried with open internet, still it does not work.
Please advise as to what should be done. I want to make it work with Extension builder 2.0 only.
-Kavya
26. Re: Unable to sign in to CS Extension Builder
Devendar_kumar Oct 28, 2013 4:43 AM (in response to Dhwanil_3)
