Do you have any suggestions for getting Captivate 7 trial running on iMac with OSX 10.8.4 and 8GB RAM? Thanks in advance.
The application starts up, but Create New>Blank Project causes the application to hang (spinning wheel).
For what it's worth, Console error log reports (amongst other logging info):
12-08-13 16:42:02,452 Adobe Captivate[537]: *** process 537 exceeded 500 log message per second limit - remaining messages this second discarded ***
12-08-13 16:44:17,976 spindump[549]: Adobe Captivate [537] didn't gather any samples due to audio running
Clearing cache/preferences/disabling audio for recording: doesn't help.
PS. 1. : A project from Captivate 5.5 can be loaded and slides are shown, but the moment an item in a slide is clicked to start editing, the Captivate 7 applications hangs.
PS 2. : After opening a Captivate 5.5. project, it can be saved (unedited) from Captivate 7, but files are huge. After re-opening the project (just saved from Captivate 7) in Captivate 7 again, any attempt to edit a slide will cause Captivate 7 to hang.
Hi there,
Can you try recreating Captivate 7 Preferences and then launch Captivate:
Open Finder-- Go to Folder-- "~/Library/Preferences/Adobe Captivate 7", rename Adobe Captivate 7 folder and make sure you have closed the Captivate first, and then relaunch.
Create a blank new project and check whether there is any improvement?
P.S.: Recreating preferences will reset Captivate settings and customizations to default, that will not make any change in your Project.
Thanks.
Thanks for your response.
Unfortunately that doesn't help. I'd really appreciate any more suggestions to get it working. Is Captivate 7 compatible with Mac OSX 10.8.4?
Hi there,
Captivate 7 is compatible on MAC 10.8.4.
Can you create a new user account (admin user), then log off, and log in with that new user account.
Launch Captivate 7 in that new user account, and see if that makes any difference.
Thanks.
Hello Varun,
thanks for your response.
Unfortunatly that didn't solve it. I've also tried a full uninstall and re-install, and also with the iMac started in safe mode. The symptoms remain the same. After force quitting Captivate in the safe mode, and restarting, the iMac preferences were partly corrupted.
I'm not sure if this is an OS X bug, or a Captivate bug. However I can say none of the other applications hang.
I really hope there will come a solution for Captivate 7 hanging. As it stands now, we'll not be upgrading to Captivate 7, and re-develop our courses in another tool. Which is a pity - all of our other Adobe products work fine.
Hi Sonja
I've reported exactly the same issue and spent many hours with Adobe help with no resolution so far. The issue has been escalated and I should hear more tomorrow. If a solution comes up I'll post it here for you.
Cheers
Michael
Hello,
@stotan : Please share your contact information on tcssup@adobe.com
@sonja : Do you have any other Adobe application on your MAC ?
Vikram
@ Michael: thanks Michael
@ Vikram:
Yes (all on Mac OS X): Photoshop Elements 11, Premiere Elements 11, Dreamweaver CS 6, Adobe Reader, as well as applications which are also installed in the process - such as Adobe Captivate Analyser, AC Reviewer, Adobe Media Player, etc
Hello,
Please share you contact information on tcssup@adobe.com.
I will contact you to find some more information.
Vikram
Was this issue ever resolved. I just recently upgraded to Captivate 7 for Mac OS and am experiencing the same thing. It works on my PC, so I'm not sure why it's not working on the mac.
It's a new mac, I've had it less than a week. When I launch the packager, I get the button to browse for the appropriate directory. Once I've selected the directory - the application hangs.
~m
Not that I know of. We shared our contact information with Adobe support - no reply yet. It doesn't give much faith, and we're now evaluating another application - in spite of having to redo our previous work unfortunately.
I'm having this issue too. Very strange. At first I thought it was because I have 2 versions of Captivate on my Mac (version 6 and 7). I was using both versions with no problem for months now, but now neither of them will open on the Mac. Still works fine on my PC.
The issue first happened about a week ago with Captivate 7. I went to open it, the icon bounced around for a while, then just stopped. I tried reinstalling it and it worked again... for about a week. Now once again it is not working, and the reinstalling trick is no longer fixing it.
Does anyone know if Adobe is working to fix this glitch?
Wanda
Hi there,
Can you please provide few more info to understand the issue?
1. Your MAC OSX version?
2. Captivate is on trial or it’s a licensed version?
3. if it is licensed version, Can you please try deleting preferences by double clicking on the 'CleanPreferencesMac' app from <captivate Installation dir>/Utils folder and see it resolves the issue or not
Nimmy Sukumaran.
Hi Nimmy,
I was on the previous version of Mac when the problem first happened (but at that time the reinstall worked out). Now I'm on the new Maveric operating system, and not even the reinstall is working.
I am working with a licensed version (I should have read the thread title before as I see this is also an issue with the trial version). I don't know if it makes a didfference, but I've been downloading/installingn from the trial version because the new Mac does not have a disk drive. But I am using my licence key that I purchaesd several months ago.
I tried following your suggestion of running the "CleanPreferenceMac" app, however it did not do the trick.
Wanda
Since you mention you are on Maverick, you need to be aware that no version of Captivate currently works on that version of OSX.
Please see this thread:
Thanks for the heads up. Glad to know it's not just my computer... but that's horrible adobe couldn't keep up to be ready for the Maverick release. People don't have time to check that all their software is compatible for new OS, and with Adobe you would think that such a big company would be more on the ball.
Why does everyone thing 'bigger companies should be more on the ball'?
I don't get this.
In my experience the bigger a company is, the LESS likely they are to be 'on the ball'. The MORE likely they are to drop the ball from time to time.
True enough - experience says that bigger companies drop the ball a lot. Certianly more can go wrong. But I work for a small, not for profit company educating Deaf adult literacy learners. We are very small, but our needs are huge as far as developing resources for our students. As such a small organization, we don't exactly have the IT department and funds to watch everything in the tech world. I can appreciate (and even anticipate) glitches here and there with upgrades to the OS, however to not be able to run one of our key software is a really huge hit to us. Hindsight is always 20/20 - and if I could do it again, I would have waited to upgrade the OS.
All my other Adobe software is functioning fine (from what I have used thus far) - it's only Captivate that doesn't seem to be as big of a priority for Adobe for some reason. Are educators not as important?
Hi Wanda
Educators are really really important . It is just that we missed the early window of warning users not to upgrade to 10.9 OS .. See my blog post on the issue and solution
http://blogs.adobe.com/captivate/2013/10/maverick-10-9-upgrade-warning.html
Sorry about the inconvenience caused
Regards
Suresh J
Senior Manager Engineering - Adobe Captivate
Hello ,
The update of Adobe Captivate for the Mavericks has been released ,Please download it from the link below
http://www.adobe.com/support/captivate/downloads.html
Please make sure while updating Adobe Captivate must be closed .
Himanshu
