2 Replies Latest reply: Oct 29, 2013 11:11 PM by Varinder.Saini RSS
    ClearScan resulting in distorted text
    GeorgeNelson Community Member
      I've been using the trial version of Acrobat Pro X for Mac and have attempted to OCR the text on several pdf's i've been working on.  When using any of the OCR options, even ClearScan on 600dpi the text becomes illegible and very distorted.  Has anyone else encountered this problem and do you know how to fix it?
        • 1. Re: ClearScan resulting in distorted text
          CtDave CommunityMVP
          OCR "Searchable Image (Exact)" leaves the image "exactly" as-is. No tweaks.
          The OCR output is not visible. The OCR output uses text rendering mode 3 (the glyphs have no stroke and no fill).
          Consequently any post process visual display issues would stem from something else.
          OCR "Searchable Image" does tweak the image some (e.g., deskew).
          ClearScan replaces bitmaps of characters recognized with an Acrobat internal font.
          If a bitmap of character is not recognized the bitmap is left as-is.
          ClearScan outputs visible glyphs.
          How these glyphs are rendered is a function of the display hardware and its associated software.
          Be well...
          • 2. Re: ClearScan resulting in distorted text
            Varinder.Saini Adobe Employee
            Could you please share the PDF file on which you are seeing this issue. Is it happening for that specific PDF? or is it happening for all the pdfs?
            Varinder
