Choosing export bitrate for local playback ...
fredowww66 Oct 30, 2013 7:40 AMWhat is the best choice for bitrate export for using the file on an emtec multimediadisc (connected to TV hdmi, TV hd)
Settings of my clipimport you can see hereunder.
Overall bit rate mode : Variabel
Overall bit rate : 25,1 Mbps
Maximum Overall bit rate : 28,0 Mbps
Bit rate mode : Variabel
Bit rate : 23,7 Mbps
Maximum bit rate : 25,0 Mbps
All other info about import at the end of the message.
Subquestion: what is now my highest bitrate in the original file ? Is it 25 or 28 ???
For export I tried several bitrates. Because it's a local disk and your own movie (I not gone make a thousand movies :-) ) I thought it was a good idea to use high bitrates...
I have a exported movie where the playing is at a moment (or sometimes moments)not fluently and even sound is not fluently at that moment. It's a typical part where videocodec can compress much (big yellow flowerfield, camera goes very slowly up). I tought first that I have to take a higher bitrate. Footage is clearly sharper than but at this very moment the playback was still not fluently, even worse.
Also my emtec disc has more not fluently action when I use 50fr in stead of 25fr I've noticed.
So then I started to do the opposite : lower bitrates and 25fr. These seems to solve it ... but image is not as sharp ...
So my question is wich bitrate (in Mbps not Kbps) (export to h264/mp4 1080p 25f) for (very) good quality but with 'guarentee' that I plays good on a 4 years old full hd emtecplayer (s800h)?
Should I choose the same bitrate as the import or is it wise to go higher ?
What I don't understand is that videosites asks much higer bitrates for 1080p footage ???
Here is the mediainfo from my standardfootage - Camera Panasonic HC-X900:
Algemeen
Complete name : D:\Fredo\Video\Basisvideo\Le Crotoy\00004.MTS
Format : BDAV
Format/Info : Blu-ray Video
File size : 118 MiB
Duration : 39s 345ms
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.2
Format settings, CABAC : Ja
Format settings, ReFrames : 2 frames
Format settings, GOP : M=3, N=24
Codec ID : 27
Duration : 39s 320ms
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 50,000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressief
Bits/(Pixel*Frame) : 0.228
Stream size : 111 MiB (94%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : 129
Duration : 39s 360ms
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 kanalen
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48,0 KHz
Bit depth : 16 bits
Delay relative to video : -40ms
Stream size : 1,80 MiB (2%)
Tekst
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Duration : 38s 816ms
