File upload doesn't work and no error! What's going on?
Jun 23, 2006 Jun 23, 2006
We are migrating our intranet from ColdFusion 5 on Solaris to ColdFusion MX 7 on Linux and I'm testing out the existing applications on the new server. The processing page for a file upload is using CFFILE with ACTION="upload". The page finishes processing fine, no error, and continues as if it was successful but the file never actually gets to the destination directory. I tried with larger files and it did take longer (so the file appeared to get transmitted), but it still does not get saved to the server's file system. This all works fine on the current system running CF5. I've tried the CFFILE destination with and without a slash at the end - no difference. We have ColdFusion 7.0.1 installed. Hot fix 2 has been applied but that did not fix the problem.
Any ideas?
Advanced techniques
1.4K
Can you see if the file is getting to the webserver's (not ColdFusion)
temp file directory?
When a file is uploaded from the browser the webserver(IIS|Apache|etc)
upload it to a temp location, then all CFFile does is copy the file
from the temp directory to where ever specified.
So you can see if the problem is failing before or after this point.
> Any ideas?
I figured out that the permissions on the directory where the file was supposed to be put were not set correctly (they had to be owned by Apache), but that brings up 2 more questions:
1. Why did I not get an error if ColdFusion could not write the file to the directory? It wasn't logged either.
2. Why are the spaces in filenames that are uploaded with CFFILE not being replaced with underscores like they were in CF5? It still seems to be working, but I'm confused as to why this feature would change.
Thanks.
Is there a chance the error was somehow trapped or suppressed?
I didn't know CF5 did this? I did not use 5 for very long. Pretty much
went from 4.5 to 6.0 several years ago, now on 7.01|2.
I did not put any code in (like CFTRY) that could have caught it. Is there something else that may have suppressed an error that I'm not thinking of?
Have you ever run into problems reading, editing or deleting files on a Linux system that had spaces in the filenames?
Apr 04, 2007 Apr 04, 2007
I'm having a similar problem... We upgraded from CF 5 to 7... and if you upload a really small file, it works fine, but if you upload something over 300 K, it just goes to a blank page... and it doesn't even get to the cffile.. I put something like Done followed by a cfabort before the cffile and I don't even see that. Is there a new setting for max upload? In CF Administrator we have "Maximum size of post data" set to 500 MB so that shouldn't be a problem.... we also upgraded to IIS 6 and Windows 2003
Apr 05, 2007 Apr 05, 2007
I found the solution:
http://www.adobe.com/go/8d933f86
I had to replace my forms and inputs with cfforms and cfinputs
Apr 09, 2007 Apr 09, 2007
I have tried this but that solution does not work for me. Did it work for you?
Apr 10, 2007 Apr 10, 2007
We also had to have users who tried to upload since we went to MX7 clear their cache (Tools -> Internet Options ->Delete Cookies & Delete Cookies) and then it worked. Luckily we only have 800 users and only a few dozen tried to upload something big in that week.
Documentation
