I keep getting Oops This document couldn't be opened on my Kobo once I've transferred my books over, they show on kobo as blacked out squares, what am i doing wrong.
Have you authorized the Kobo?
While it is plugged in to a computer running ADE, it should appear in the left pane.
use meny/Help/Authorize Device to copy authorization from the computer to the Kobo.
Hi, yes I've done that, I've checked on the Adobe Digital and it says my Kobo is authorised and i've checked my setting on the Kobo and that says its authorised, both ID's are the same. Thank you for trying to help.
Does this apply to all books or just some?
It could be a bug/limitation on the Kobo.
When I had a Bookeen Opus I found a small number of books that it could not read,
even though ADE could read them, and other books (including DRM ones) worked fine on the Bookeen.
Luckily, they were not books I was that keen to read ...
I have not had similar issues on my Sony PRS-350.
Thank you, that's good to know, I though I was being totally dumb, not being able to get it work. I've just received an email from the supplier of the books that I bought and they are giving me a refund, I will try and buy them again from another site. thanks for your help
It might be worth signing up with your local public library to borrow some eBooks ~ at least you can experiment with reading DRM books free that way ...
