Is it possible to create a multilevel navigation in Adobe Presenter with an arrow that you could click to see the other level ?
Hi
It is possible. But there will be a few restrictions
You can go to a different slide based on :
1. if the user has passed the quiz or not
2. If a shape or an object has a hyperlink pointing to some other slide
3. When the audio hits some point (you can do this in audio editor)
4. In the slide manager we have the go to option which can take the user to the desired slide as designed by the author
All this options will be visible once set and published using presenter
Mahesh
