attempting to install latest flash player on mac 10.9, freezes at 95%, have uninstalled & reinstall
restarted in safe mode, same issue
anyone else having this issue?
Please try uninstalling Adobe flash player using this utility.
http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-mac-os.html
After that, download the latest version of flash player and install. Make sure you close all the application while installing.
Thanks but this is the uninstaller I used after the installer failed the first time, thank you.
Please try installing this new 11.9 beta version
http://labsdownload.adobe.com/pub/labs/flashruntimes/flashplayer/flashplayer11-9_install_mac.dmg
Thank all that replied to my post. I was able to successfully install Flash Player following this procedure:
1. Mac HD/Library/Internet Plugins
Verify that the Flash Player.plugin file is not present. If it is, trash it.
2. Mac HD/Library/Application Support/Adobe/Flash Player
Verify that the Flash Player Install Manager folder does not exist. If it does, trash the whole folder
3. Download the offline installer here: http://fpdownload.macromedia.com/get/flashplayer/current/licensing/mac /install_flash_player_11_osx....
4. Restarted in Safe Mode (shift key)
5. Mounted install_flash_player_11
right click on installer -> show package contents
Contents -> Resources -> Adobe Flash Player.pkg (installed correctly)
Glad that worked, Dave.
I try to avoid having people install ANYTHING in safe mode (Mac or Windows), because usually when you have to go that step, it's a sure sign that your OS is unstable, and it can cause worse problems than just an app not installing.
I've read quite a few "horror stories" in the Apple Forums re: "Mavericks destroyed my Mac". I've been really fortunate, I guess, because other than about a ten second lag when searching folders in finder via third party apps, it's been a really smooth transition.
