Ray-tracing & GPU on 12.1
Nov 02, 2013 Nov 02, 2013
When opening 12.1 I now get this message:
Ray-tracing on the GPU requires an approved NVIDIA graphics card
and CUDA 5.0 or later. For now, ray-tracing will be used by the CPU.
I have a GTX285 updated to 5.5.28 - any idea what's going on?
Thanks.
20.5K
The warning doesn't say I don't have enough memory, it says I need CUDA 5.0 or higher and I have 5.5.28.
Is that the same warning different wording??
Oops. Sorry. Wrong message.
Let me look into what might be causing yours.
Guest
Add me to the list as well.  Have AE Creative Cloud (latest release) with an IMac Late 2013 with the following NVIDIA chipset:
NVIDIA GeForce GTX 780M 4096 MB.  System has 32GB of RAM as well.
//Previous post was by previously logged in account. BosleyBeats is having the similar issue.
//REPOST:
Solved this issue on my system with the following CUDA drivers: http://www.nvidia.com/object/macosx-cuda-5.5.28-driver.html
If you're using a PC, I suggest looking up the equivalent drivers on Nvdia website and give that a try.
Good Luck.
Nov 04, 2013 Nov 04, 2013
Hmmm ... not mine. I've had those drivers all along and I'm still getting the problem.
Hi all -
TRY THIS:
#1: open up AE and jump into preferences.
#2: select the PREVIEWS panel and then GPU INFORMATION
#3: Select your GPU under the Raytracing dropdown and click the ENABLE UNTESTED, UNSUPPORTED... checkbox
#4: It still may say 'unsupported', but ignore that and OK everything you just did.
#5: Shut down and restart AE.
This worked for me. If it doesn't immediately work for you, you might want to throw a system restart after step 5 and see if it "takes" your card.
Mine's grayed out even though as you can see, I have a supposedly approved card.
have you restarted your system lately?
Just did and no joy. Very strange.
Same screen?
Ok. I am going to assume you are on a Mac. You know how to add your card to the supported card lists? If not, simple version is to "show package contents" when right clicking on AE. In the Contents folder are two txt files that are apparently no longer relevant with the new CC update, BUT I'd throw your card in them anyway. File names are: intel_ogl_supported_cards.txt and raytracer_supported_cards.txt
Add your card as 'GeForce GTX 285'
If that doesnt clear it up or if you've done that already let me know... I'll keep thinking.
Hey, I notice that you still had CPU selected from the drop down. Can you send me a screenshot of what it looks like when you have your GPU selected?
Thanks for taking the time to help me here OzzyofLA. Much appreciated.
The card is already in raytracer_supported_cards.txt and won't let me add to intel_ogl_supported_cards.txt, says it's locked.
GPU is also grayed-out in the dropdown.
Copy and paste the txt file to your desktop so you can open and edit it there. Then copy it back. Make sure its the same name.
That is just to be sure it doesn't easily solve your problem. It very well may not, but let's eliminate what we can.
Do you have CUDA fully installed? You should be at version 5.5.28 in System Preferences.
Screen Shot 2013-11-04 at 7.39.24 PM.png <<<
Ok, I've added the text and rebooted but it's a no go.
I've had the 5.5.28 since it came out and didn't have this problem until I installed 12.1
Strange I seem to be the only one on a Mac with this problem grrr.
Hey, you made a mistake and placed your card in the UNSUPPORTED ogl .txt file. Remove it from there and put it in the SUPPORTED .txt.
Let me know what happens.
I don't have a SUPPORTED.txt. I do have a raytracer_supported_cards.txt though and it is in there - see above.
You removed it from the UNSUPPORTED txt though, yeah? You can add in the following txt file by just duplicating any of the others and put your card in it:
Then restart and let me know what happens.
Yes, removed it and put it in supported and rebooted - no luck.
Any idea what GPUSniffer is in the folder? Could be promising, no?
What is all the code in that file? Pretty sure GPU sniffer is what allows Adobe products to recognize your card. Nothing too special. Here is what My intel_ogl txt file looks like:
Dunno. I duplicated the raytrace txt and renamed it and now it looks like yours. No luck after a reboot though.
Anymore info Todd?
I  let OzzyofLA remotely have a once over on my comp and he says all is good except it may be Mavericks.
Anyone else getting this warning using Mavericks? Not the free space warning but the 5.0 or higher driver warning when you already have 5.5.28 warning?
Nov 05, 2013 Nov 05, 2013
I had your same problem, but I solved it by re-installing again the nvidia driver and the cuda installer.
now I can select the GPU and the "Enable unsupported..." and everything looks normal again.
hope it helps.
