Locked
How to get a result from a database to check if record exists?
Nov 03, 2013 Nov 03, 2013
Hello guys,
I'm trying to access a record from a table in the database to check if exists to select a checkBox.
Here are my codes so far.
This is the php code:
public function mpiIICheckIfExist($item) {
  $stmt = mysqli_prepare($this->connection,
  "SELECT mpiIIId
  FROM $this->wo2mpi2ii
  WHERE wo2mpiId = ? AND mpiIIId = ?
  LIMIT 1"
  $this->throwExceptionOnError();
  mysqli_stmt_bind_param($stmt, 'ii', $item->wo2mpiId, $item->mpiIIId);
  mysqli_stmt_execute($stmt);
  $rows = array();
  mysqli_stmt_bind_result($stmt, $row->mpiIIId);
  while (mysqli_stmt_fetch($stmt)) {
       $rows[] = $row;
       $row = new stdClass();
  mysqli_stmt_free_result($stmt);
     mysqli_close($this->connection);
     return $rows;
When I test the code in Flash Builder like this {wo2mpiId:1, mpiIIId:1} I get wha I expect "mpiIIId = 1"
My problem is that I can access this variable the way I need to.
Here is my mxml file.
     protected function getIItems(event:FlexEvent):void {
          getMpiII.token = mpiService.getMpiIndividualItems(mpiItemId);
          getMpiII.addEventListener(ResultEvent.RESULT, genItems);
      protected function genItems(event:ResultEvent):void {
          mpiVO.wo2mpiId = mpiId;
          for (var i:int = 0; i < getMpiII.lastResult.length; i++) {
          iBox = new spark.components.CheckBox();
          iBox.id = getMpiII.lastResult.id;
       // ***************** PROBLEM SECTION -- I Trying to do an if statement here but I can't get the return value to compare
          mpiVO.mpiIIId = int(iBox.id);
       //trace(mpiVO.wo2mpiId); // expected value - OK
       //trace(mpiVO.mpiIIId); // expected value - OK
          existMpiII.token = mpiService.mpiIICheckIfExist(mpiVO);
          trace(existMpiII.lastResult[0].mpiIIId);  // NOTHING HERE
       // ***************** END PROBLEM SECTION
          iBox.label = getMpiII.lastResult.individualItem;
       //iBox.addEventListener(MouseEvent.CLICK, checkboxHandler);
          iFormContent.addElement(iBox);
     <fx:Declarations>
       <s:CallResponder id="existMpiII" result="existMpiII.lastResult"/>
       <s:CallResponder id="getMpiII"/>
       <s:CallResponder id="createMpiII"/>
       <wampiservice:WampiService id="mpiService" showBusyCursor="true"/>
     </fx:Declarations>
Please help, if need more codes let me know.
Thank you, Robert
465
