I wasn't aware that we were discussing Google maps, ~Aaron,
but it makes no difference whether or not that is the case. To test
the panning of Google Earth, I fired it up and found that while the
shortcut key combination (ALT+SPACE+M) is not available on the
window, the concept of manually scrolling the application window
works just fine; just select "Move" from the Title Bar left-end
menu, then use the ARROW keys in conjunction with the PRTSCR key as
we've already discussed, and use the ENTER to "place" the map in
its final position.
To repeat my earlier caution, the application window needs to
be in "restore" mode because if it is maximized, it cannot be moved
(of course).
Last thought: There are some cases where full-motion capture
might be preferable to a manual panning operation, and this might
be one of them. In any case, best of luck, " deidrelynn".
