Show 1 reply
1. Re: I'm having sync problems
Rohit (Story Team) Nov 5, 2013 10:46 PM (in response to cxgerson)1. Share Project Issue: When sharing with a new user, you will have to first 'Add' it to the sharing list. So the steps would be:
- click on share button
- type in the email address
- select the role
- click on 'Add' button
- click on 'Share' button.
2. Sync Issue: If the line producer has made changes to the same shared schedule document then you should be able to see it.
But if by 'number of revisions' you mean a different copy of the original document then you will not be able to see those changes as those documents are not shared with you.
In that case you should ask the user to share those documents with you.
