How can I get Show link in context-sensitive help to show master help TOC?
Guest
Apr 06, 2007 Apr 06, 2007
I am using a master project with 6 or 7 sub-projects. When using context sensitive help, if a topic from a sub-project is displayed and you click on the Show link, the table of contents that appears is only for the sub-project. I want the entire table of contents to appear--the one that includes every sub-project. Is there a way to do this?
393
The way to do it is to call the csh topic via the main project using the startpage#target method.
See the topics on my site about calling webhelp. Read the one on using URLs first as that will give you the idea and you will be able to test it. If your developers are using map ids, I believe they can achieve the same result. Hopefully the topics I link to on that area will explain how.
Guest
Apr 17, 2007 Apr 17, 2007
Peter, thank you for your reply. I read the article and have a couple questions. Right now I'm trying to insert a "Home" image in each topic of each sub-project. The Home image will have a hyperlink to the default topic in the master project. I'm assuming I select "file" in the hyperlink drop-down and choose the default htm file of the master project. Is that correct?
I saw another post on this forum with the same issue. You mentioned in that thread that RH will replace the absolute path with a relative path if the projects are in the right structure? What is the correct structure? I have the master and all sub-projects on my D drive, on the same level. When I publish all of the projects on a different drive, the files for the sub-projects are published to the mergedProjects folder of the master project.
Guest
Apr 18, 2007 Apr 18, 2007
Why do it the hard way? Why not put a single button on the toolbar that does that. See this topic. http://tinyurl.com/2pyc9r
The correct structure is, of course, the one I propose in my topic on merged webhelp! 🙂 Others will probably work so it is trial and error.
Just gave this some more thought and of course you are trying to insert a Home button in the topic to call the default topic in the parent but, I suspect, believing that will open the full TOC. It will not. You need to link to the startpage of the parent as that will open the full merge with the default topic.
I think it will also leave the CSH topic open which is messy. Better to call the CSH help so that it is opened using the startpage#target method.
RoboHelp Documentation
Download Adobe RoboHelp
