1 Reply Latest reply on Nov 6, 2013 8:21 AM by Sreekanth_S
    How do I change the phonetics in the TTS in Captivate 7?
    rscharfer
      Hello,
      I have successfully used vtml tags to add some pauses and slow down the TTS produced by Captivate.  I haven't been able to change the phonetics, however.. .Any tips on how to do this?  is there a phoneme alphabet that works better than another in Captivate?  I have tried "alphabet="ipa" and alphabet="x-CMU" and neither of them had any effect.
      Thanks for any help?
        • 1. Re: How do I change the phonetics in the TTS in Captivate 7?
          Sreekanth_S Most Valuable Participant
          You can use the Captivate dictionary for this purpose.
          Go to C:\Program Files (x86)\Adobe Captivate Voices 7\VT\<Voice Artist>\M16\bin, and launch UserDicEng_<Voice Artist>.exe.
          In the dictionary, click File Open and select userdict_eng from the C:\Program Files (x86)\Adobe Captivate Voices 7\VT\<Voice Artist>\M16\data-common\userdict folder.
          Click Add Word and select the Pronunciation Symbol radio button below the Target field. You will now see the pronunciation symbols which you can use.
          Note: Due to a bug in NeoSpeech 64bit installer files, you must install the 32-bit NeoSpeech voices even if you are on a 64-bit system.
          Sreekanth
