Upgraded to RH 10. We did initial testing w/Internet Explorer 8 and everything seemed fine. However, some users are now reporting problems. (Note: we do not control IE upgrades so we cannot just upgrade them to IE 10).
I thought that we would have problems only if we used the multiscreen output but now I suspect IE 8 is the problem.
Is there anything that can be done on my end to get the project to work in IE? If not, anything besides rebuilding to make project backwards-compatible w/RH9 again?
What’s your help output flavour? It’s not clear if you’re talking about WebHelp or not. What sort of problems are being reported?
Yes, WebHelp.
Problems are: Index not working correctly (term starting w/A will not pull up "A" terms), Search not working correctly.
The problem is not consistent. Some people have the problem and some do not; however, they do have IE 8.
Sounds like different browser security settings, not the version of IE, that’s the problem. Can you reproduce the issues yourself?
Yes, I have 2 machines and can duplicate on one of them.
I should add: some settings on the machine w/the problem are controlled only by sys admin.
Then it definitely sounds like browser security settings – you need to establish your minimum settings and publish that knowledge so that sys admins can configure the client browsers to work.
Yes, I am fully patched. The problem is inconsistent. For example, yesterday I could see some problems and now they are not there, and I changed nothing on the machine.
Do I need to step back to RH 9?
It’s nothing to do with RH – nobody’s experiencing issues with IE8 – it’s IE10/11 and Chrome that have problems right now
OK--but you do mean IE8 WITH RH 10, right?
yes
Hi Jeff,
Chrome was working fine a month or two ago for my pages. Now I'm getting nothing, endless flickering of the "Stop loading this page" button and tab loading icon. Is that the current problem with Chrome that you are referring to?
Yes, and both Willam and Adobe have released a fix (which turns out to be the same) – check this thread: http://helpx.adobe.com/robohelp/kb/webhelp-output-fails-load-chrome.html
Update: It appears that output didn't get moved correctly to the server. We have reuploaded the output and things appear to be working normally. I will post if we encounter additional issues.
I have one user on IE8 who is complaining about a flickering screen. Should I try the fix mentioned above?
You could try it, but that fix was for Chrome, not IE8 – if nobody else is experiencing it, I would suspect a browser setting on the suspect machine.
Thanks Jeff,
Finding fixes for RH10 is not easy. The Product Updates link on the page below takes you to a demo download page. The subsequent "See all downloads" link shows you all 5 billion adobe products.
I just bookmark this page - http://www.adobe.com/support/robohelp/downloads.html
I'm seeing image map rectangle borders displaying after clicking in Chrome? The image is clean to start but when you click the hotspot then the rectangle appears in orange and remains. In IE8 I get a dotted border but only while the mouse is down. In FF (latest) I get no border which is what I would expect and prefer.
I don't see this reported anywhere, wondering if anyone else has seen this?
It seems that IE is adding an outline. The following thread has several
suggestions to fix it:
http://stackoverflow.com/questions/4351827/how-do-i-get-rid-of-this-border-outline-for-my-image-map-areas-when-clicked-os
Greet,
Willam
Ok, then you can start tweaking settings to see if it has any impact – BTW, you are fully patched-up on RH10, right?
