1
Where do I install fonts in photoshop cc or can I?
Nov 07, 2013 Nov 07, 2013
I have a windows 7 system and I installed the fonts to \Adobe\Adobe Photoshop CC\Required\PDFL\Resource\Fonts but when I go back into Photoshop, they are not there.   Can anyone help me out please?
169.8K
Community Beginner , Mar 21, 2014 Mar 21, 2014
Ok, I got a resolution after being bounced around and with support for several hours. They finally realized that I had to create a folder called "Fonts" in C:\Program Files\Common Files\Adobe and put the fonts there. I was thrown off because the Fonts folder already existed here, C:\Program Files (x86)\Common Files\Adobe, and I assumed that would be the place to put them. hope this helps
Adobe
Is there a reason you don't just want to install them into Windows?
Drag them into the (I think normally hidden) C:\Windows\Fonts folder in Explorer.
-Noel
Nov 08, 2013 Nov 08, 2013
What Noel said, plus, don't forget to check out Typekit if you have a CC subscription.
Mar 12, 2014 Mar 12, 2014
I would like to install fonts for photoshop only as I am a web developer. I would like to see my page as the public does while I am developing but need the fonts in photoshop to translate the designers work. I used to just drop the fonts into C:\Program Files\Common Files\Adobe\Fonts but that folder no longer exists. I tried in C:\Program Files (x86)\Common Files\Adobe\Fonts but the fonts don'e show up when i try to edit text in photoshop
Mar 13, 2014 Mar 13, 2014
You didn't find putting them in C:\Windows\Fonts acceptable for some reason?
-Noel
Mar 14, 2014 Mar 14, 2014
no it does not appear in the dropdown. some pertinents….I had a trial version of cs6 installed and I still see remnants of it…am I dropping in the right spot? ….also my .ttf is from font squirrel, is that the best place to get a ttf?
Did you close and restart Photoshop after installing the font(s)?
Photoshop sees fonts installed into Windows, and dropping fonts (via File Explorer) into Windows\Fonts is how you install them.
I have no knowledge of "Font Squirrel".
-Noel
thanks for trying to help Noel, Adobe confirms that on windows 7 if you drop the .ttf here, C:\Program Files\Common Files\Adobe\Fonts , it should show up in the font drop down in photoshop. I’ve done a complete unisnstall clean up of adobe and am now installing CS6. will restart, drop file, restart again to see if file appears. could just be a bad file. fontsquirrel.com, great site
well I did a complete clean and I installed cs6 instead of cc, all old settings and workspaces were gone after I rebooted so I’m fairly certain it was a clean uninstall. Dropped file that I downloaded from google fonts into the folder but still does not show up. I’ll post here if I find a resolution
Nov 10, 2016 Nov 10, 2016
This is the proper way! Works perfect! Thanks mate!
Jan 15, 2017 Jan 15, 2017
I tired this but it didn't quite work.
Aug 29, 2018 Aug 29, 2018
Just worked for me, installed a load of ttf files and only some of them appeared in Adobe programs, tried all sorts and didn't think this was going to work but it did! - thanks theresaweb
Participant ,
Sep 30, 2019 Sep 30, 2019
This is perfect! I was looking for a way to install fonts for Photoshop only. Thank You!
Mar 30, 2020 Mar 30, 2020
Thanks! This method works!
Jan 11, 2017 Jan 11, 2017
Thanks dude it works!
Hello,
I have a similar issue. I am still working out what is going on with the font but the font I have been given to use is not in a .ttf format. I am therefore unable to install it as a font in Windows and I've been told it is a Photoshop font. Typekit is not activated on my computer and the font I must use is not in typekit.
Suggestions would be much appreciated.
Claire
Hello Claire.
I have come across with same problem too. You must have the .ttf extension font file to install it on C:\Windows\Fonts directory. I have sent a private message to you the webpage that you can hopefully and easily find and download the font file which you are looking for in .ttf extension.
Brilliant, I'll give it a go!
Feb 04, 2017 Feb 04, 2017
Does anyone have any idea if I can import a font?  Photoshop elements 9 has several fonts I was using for a project, but I had several issues with 9 (including uninstalling and would not update).  Now have the newest elements 15, but fonts are missing that I was using... can I possibly import the fonts from 9 to 15?
Lee
Aug 22, 2017 Aug 22, 2017
Apr 02, 2019 Apr 02, 2019
No doubt Adobe Photoshop is one of the most famous and top ranking editing software and now you can also take advantage of cloud with adobe CC.
I might suggest you a proper way to install fonts in Photoshop.
It would be difficult to write & share pictures here so, this the place where i got my solution
https://www.experthoot.com/how-to-add-fonts-to-photoshop/
You don't have to restrain yourself to the limited fonts offered by Photoshop just download fonts from google & use them in photoshop.
Dec 23, 2019 Dec 23, 2019
Some fonts are installed in the regular fonts folder of windows as stated by many respected readers,Problem arises when the installed font in windows appear in all other programms eg in microsoft word,notepad---BUT REMAINS MISSING IN PHOTOSHOP--
Thus question raised by readers is very justified and has not received justified answer.Sir,my object is not to offend anyone but I am trying to seek the solution from learned readers---Bakhshish Singh PUNJAB_INDIA
