Hi there.
I'm using a MacBook Pro 13" Mid 2012 with OS X 10.9
When I start installing the latest Flashplayer it stops at 50%
I don't know what to do.
Please help
Thank you, but I tried it and it failed
Failed how?
I did "clean installs" on three machines (Snow Leopard, Lion and Mt. Lion) last night. I did them just like the instructions.
If you download the FULL installer (the linked DMG in the instructions), it can, and should install in a matter of seconds.
I followed every step and when I started the full installer, it stopped at 12%. Installation failed.
Create a new (admin) user account and try it under that account.
Tried. Didn't work. Same text.
Go to: Applications/Utilities
Double click the Disk Utility and "Repair Permissions" on your Hard Drive.
THEN try the "Clean Install".
Tried. Nothing changed
There are intructions to install it via Terminal, but not everyone is comfortable with that, http://forums.adobe.com/message/5059595
Good News: I solved the problem
I just reinstalled Mavericks and everything works as it should
Thanks you for your time and help
