We have been using the same site for a couple of years. In the last week when I try to publish it errors out with "parameter incorrect". The Intranet address has not changed. It will actually push the file over, but with errors such as not all .jpgs will display correctly. Can someone help please??
Something must have changed – what about deleting all the files on the server & republishing them?
quite frankly, that solution terrifies me but thanks 🙂
Mmmh. Did you update SharePoint or change the authentication structure?
The easiest way to publish is simply to map a document library as a network drive. You can then publish to a network drive and let Windows handle the SharePoint quircks
Greet,
Willam
You might also try the Source Control forum – lots of Sharepoint discussions over there
