1. Re: Newly updated Premiere CC Crashes
Sandeep Singh Nov 11, 2013 1:56 AM (in response to DerekDevine01)Hi DerekDevine01
Please also tell which Graphics card, you are using ?
are you using any third party plugins e.g. Magic bullets etc
and please try to reset the preferences of the premiere pro from Documents / adobe /premiere pro / 7.0 / username
Sandeep
2. Re: Newly updated Premiere CC Crashes
DerekDevine01 Nov 11, 2013 8:16 AM (in response to Sandeep Singh)Thank you for the response.
Nvidia GeForce GT 650M 1024 MB
Yes I installed Magic Bullet
Tried to remove the pref file from Documents and that did not work.
I will try to uninstall Magic Bullet
3. Re: Newly updated Premiere CC Crashes
DerekDevine01 Nov 11, 2013 8:25 AM (in response to DerekDevine01)Removed all RED Giant plugins from the system. Reset Prefs again.
Still crashes.
4. Re: Newly updated Premiere CC Crashes
RMOURON Nov 11, 2013 9:19 AM (in response to DerekDevine01)Same problem. Applied same solutions deleating pref from documents adobe premiere pro.
Try to open Adobe premiere pro CC, and every time on the pluging quicklooks it craches and tell me to go to update of red gient ( i have bullet looks 2.0 latest version for maverick on OSX )
But still can not open premiere pro CC.
help required
5. Re: Newly updated Premiere CC Crashes
avanishdivya Nov 11, 2013 9:38 AM (in response to DerekDevine01)Hi Derek,
Please go to the following location & move the contents of the media core folder out.
MacHD\Library\Application Support\Adobe\Common\Plug-ins\CC\MediaCore
You can place it on the desktop then launch the program.
Try the steps & see if that helps.
Thanks.
6. Re: Newly updated Premiere CC Crashes
RMOURON Nov 11, 2013 9:50 AM (in response to avanishdivya)NO media core file included at that place.
Actually the problem is the same with adobe media encoder. The file that it crashing the opening process is Quicklooks_AE10.plugin
7. Re: Newly updated Premiere CC Crashes
Vinay Dwivedi Nov 11, 2013 9:54 AM (in response to RMOURON)Hi RMOURON,
Please try to update the plug-in it might fix the issue. If not, go to MacHD\Library\Application Support\Adobe\Common\Plug-ins\7.0\MediaCore and remove that plug-in if it is there in mediacore.
Vinay
8. Re: Newly updated Premiere CC Crashes
avanishdivya Nov 11, 2013 9:56 AM (in response to RMOURON)Try this location
9. Re: Newly updated Premiere CC Crashes
RMOURON Nov 11, 2013 10:08 AM (in response to Vinay Dwivedi)It's working for premiere pro cc & encoder cc.
So a great French Bravo !
10. Re: Newly updated Premiere CC Crashes
stevehaskin@att.net Nov 11, 2013 10:17 AM (in response to avanishdivya)How about for Windows. Premiere Pro WILL NOT RUN since running update last week. I'm in the middle of a big project and I cannot get the program to boot.
Computer: Dell Precision Mobile m6700, Win 7, 32GB RAM, nVidia K4000 card. Win 7 is up to date.
Here is the error reporting:
Problem signature:
Problem Event Name: APPCRASH
Application Name: Adobe Premiere Pro.exe
Application Version: 7.1.0.141
Application Timestamp: 526b4b24
Fault Module Name: MSVCR100.dll
Fault Module Version: 10.0.30319.1
Fault Module Timestamp: 4ba220dc
Exception Code: 40000015
Exception Offset: 00000000000760d9
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 77b0
Additional Information 2: 77b047d66f861c9bf4b14af605bb110d
Additional Information 3: 5076
Additional Information 4: 507694edd22aca9ddcf76452c7ddcef0
Also, error message is [..\..\src\TickTime.cpp-121]
I am paying for a program that does not operate and am very frustrated. I have reinstalled Windows and have tried about everything I can think of to isolate the problem, but it will not go away.
11. Re: Newly updated Premiere CC Crashes
DerekDevine01 Nov 11, 2013 10:50 AM (in response to avanishdivya)The only folder in plugins was called Rowbyte.
I removed this folder. Put one copy on the desktop and the other in the trash. Empited the trash.
No go. Still crashes when I try to used media. Currently all I'm doing is navigating to my desktop through the media browser. As soon as a video picon shows up it crashes.
