2 Replies Latest reply: Nov 11, 2013 5:03 AM by Promethe2000 RSS
    Make layer a link?
    superflashlove Community Member
      Like the message title can I make a layer a link with flash and if so how...
        • 1. Re: Make layer a link?
          Rob Dillon CommunityMVP
          A layer is simply a space in the timeline. It may contain frames. In any given frame you can place an instance of a symbol. If you name the symbol instance then that instance can be addressed by actionscript. In actionscript you can define a function that will cause an internet call to occur.
          If you place an instance of a movieClip or a button in a frame and give that instance a name then you can attach actionscript to it.
          AS2:
          instanceName.onRelease = function() {
          getURL("yourURL.com");
          AS3:
          instanceName.addEventListener(MouseEvent.MOUSE_UP,NavigateToURLExample);
          function NavigateToURLExample(Event:MouseEvent):void {
          var url:String = "yourURL.com";
          var variables:URLVariables = new URLVariables();
          var request:URLRequest = new URLRequest(url);
          navigateToURL(request);
          • 2. Re: Make layer a link?
            Promethe2000 Community Member
            First you should make a visible (transparent) button on your banner. (Insert -> New Symbol (select button)
            When you see your button on the group toolbar on right side,  drag and drop your button on to your Scene. Make sure this button cover to all your banner. After that right click this transparent button on to scene and select action. Write this script :
            Example:
            on (release) {
                      getURL ("http://www.myurl.com", target="_parent");
            İf you want to use this banner with an html in the frame, and you want to open page on same window, you shoul use  target="_parent". If you want to open a new window, you should use target="_blank"
