Can you see if the file is getting to the webserver's (not
ColdFusion)
temp file directory?
When a file is uploaded from the browser the
webserver(IIS|Apache|etc)
upload it to a temp location, then all CFFile does is copy
the file
from the temp directory to where ever specified.
So you can see if the problem is failing before or after this
point.
Grant wrote:
> We are migrating our intranet from ColdFusion 5 on
Solaris to ColdFusion MX 7
> on Linux and I'm testing out the existing applications
on the new server. The
> processing page for a file upload is using CFFILE with
ACTION="upload". The
> page finishes processing fine, no error, and continues
as if it was successful
> but the file never actually gets to the destination
directory. I tried with
> larger files and it did take longer (so the file
appeared to get transmitted),
> but it still does not get saved to the server's file
system. This all works
> fine on the current system running CF5. I've tried the
CFFILE destination with
> and without a slash at the end - no difference. We have
ColdFusion 7.0.1
> installed. Hot fix 2 has been applied but that did not
fix the problem.
> Any ideas?
