HI,
It would seem that if one is using 64 bit MS Internet Explorer as a web browser and installs Flash Player for it... Then tries to use FIrefox from Mozilla (32 bit) that it becomes a problem for Mozilla? It requires a manual install to get it working. However I would like to know if this compromises the 64 bit install for the addin in MS IE?
Has anyone else had problems with this? Should I just quit using Mozilla? Or is there a way to ensure 64Bit runs on IE and 32 on Mozilla?
Am I asking the wrong questions?
There are two (2) different versions of Flash Player plugin installed when using IE (64 or 32 bit) and Firefox. Since Firefox doesn't use ActiveX controls (no browser other than IE does anymore), it doesn't share the plugin. When you download Flash Player with IE 64 bit, there is javascript in the download page that detects the OS and browser and "pushes" the proper download.
Thank you,
That was a perfect answer, the most perfect answer I thinkg I have seen in a forum in several years. Thank you for being clear, to the point, and on track.
I try my best to be accurate.
