I have Coldfusion 10 and Coldfusion Builder 2.0 installed entirely on my local Windows 8 machine. I'm using the builtin Tomcat server.
I'm accessing the server using Remote Data Services (RDS).
When I try to run my application it won't run because the IDE runs it as https://localhost:8500/MyApp
If I copy the link and change it to http://localhost:8500/MyApp then it works.
I have both TLS and SSL enabled in Internet Explorer.
I understand that if you use JRun then you have to install a certificate, but I'm not using JRun.
So how can I either get CF Builder to not put the "s" in or get Tomcat to accept it?
Bill
Hi
Try the steps mentioned below
Open Command Prompt as Run as Admin and change the directory to C:\ColdFusion10\jre\bin
Type the command below and press Enter
keytool.exe -genkey -alias tomcat -keyalg RSA
Enter the password : changeit
Now in the this location: C:\Users\username you will get a .keystore
Open the server.xml of the ColdFusion instance : C:\ColdFusion10\cfusion\runtime\conf
Uncomment the SSl/https
<Connector port="8443" protocol="HTTP/1.1" SSLEnabled="true"
maxThreads="150" scheme="https" secure="true"
keystoreFile="C:\Users\username\.keystore" keystorePass="changeit" keyAlias="tomcat"
clientAuth="false" sslProtocol="TLS" />
NOTE : You need to add the keystore info in it as I did above
Save and restart the ColdFusion 10 Application server service
Now open https://localhost:8443 and it will work
NOTE : The https port in server.xml is 8443
VJ
Thank you for these detailed instructions. However, the problem persists.
The problem is probably related to the fact I’m unable to start my localhost server:
:ERROR: JDWP Transport dt_socket failed to initialize, TRANSPORT_INIT(510)
:JDWP exit error AGENT_ERROR_TRANSPORT_INIT(197): No transports initialized
:Error(11/12 at 01:58:47) Server is not responsive.
Do you know what I would do about that?
Bill
Is your hosts file (C:\Windows\System32\drivers\etc) looks like this?
You need to add 127.0.01 for localhost in the hosts file.
VJ
I changed it by removing the comment, like so:
Copyright (c) 1993-2009 Microsoft Corp.
This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
This file contains the mappings of IP addresses to host names. Each
entry should be kept on an individual line. The IP address should
be placed in the first column followed by the corresponding host name.
The IP address and the host name should be separated by at least one
space.
Additionally, comments (such as these) may be inserted on individual
lines or following the machine name denoted by a '#' symbol.
For example:
102.54.94.97 rhino.acme.com # source server
38.25.63.10 x.acme.com # x client host
localhost name resolution is handled within DNS itself.
127.0.0.1 localhost
::1 localhost
But no difference. Do I need to restart the CF services?
Restart the machine. What happens when you try 127.0.0.1 instead of localhost? Then try
I restarted the main service, reran and got this:
:FATAL ERROR in native method: JDWP No transports initialized, jvmtiError=AGENT_ERROR_TRANSPORT_INIT(197)
:ERROR: transport error 202: bind failed: Address already in use
As you mentioned above that if you try http://localhost:8500, it works which means there is no issue with the localhost then.
Go to C:\ColdFusion10\cfusion\bin and take a backup of jvm.config
Now open the jvm.config, Add following argument in jvm.config after the argument line (not in a new line)
-Djavax.net.ssl.trustStore=C:\\ColdFusion10\\jre\\lib\\security\\cacerts -Djavax.net.ssl.trustStorePassword=changeit
Then restart the ColdFusion 10 Application server service and run https://localhost:8443
VJ
When trying to restart the Application Server service:
I had changed it to:
Arguments to VM
java.args=-server -Xms256m -Xmx512m -Xdebug -Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=5005 -XX:MaxPermSize=192m -XX:+UseParallelGC -Xbatch -Dcoldfusion.home={application.home} -Dcoldfusion.rootDir={application.home} -Dcoldfusion.libPath={application.home}/lib -Dorg.apache.coyote.USE_CUSTOM_STATUS_MSG_IN_HEADER=true -Dcoldfusion.jsafe.defaultalgo=FIPS186Random -Dcoldfusion.classPath={application.home}/lib/updates,{application.home}/lib,{application.home}/lib/axis2,{application.home}/gateway/lib/,{application.home}/wwwroot/WEB-INF/flex/jars,{application.home}/wwwroot/WEB-INF/cfform/jars,"CLASSPATH =.;C:
Program Files
Microsoft JDBC Driver 4.0 for SQL Server
sqljdbc_4.0
enu
sqljdbc.jar" -Djavax.net.ssl.trustStore=C:
ColdFusion10
jre
lib
security
cacer ts -Djavax.net.ssl.trustStorePassword="changeit”
(I put the correct password for “changeit”).
Did I do it right?
Bill
