File Not Found Frustration
Apr 09, 2007 Apr 09, 2007
We have a system that has been working like a charm on a server running CFMX. Friday we changed over servers to W2003 and CFMX7. This system works to a point. I am able to access the index page and it displays. This page displays a menu with radio buttons. A choice is made but the page that that particular radio button is attached to gives an internal server error. The file is located in the same directory as it was on the old server. I have been struggling with this all day. Any ideas on what could be causing this would be greatly appreciated. If more information is needed, please let me know that too. Thanks!
Cheers
JK
Advanced techniques
930
It would help to know the exact error message?
You have turned on full debugging so that you get the detailed error
messages correct?
Also what does the page do?
It this a problem with all links from the index page, or just particular
one(s)?
Engaged ,
I suspect a permissions issue. Check that the CMFX7 service login name has access rights to the directory in question.
That's what I figured at first but since the index file is in the same folder, I have to assume that the permissions are ok. Any other ideas. Thanks for your response. I am just brain dead at this point!!
Cheers
JK
Actually it is looking more and more like a form issue from the index page. I am using radio buttons with a certain value and the .cfm page doesn't seem to like it.
Cheers
JK
Here is the error msg that I am recieving. To see it in action please go to https://www.mvcc.edu/cced. Select the first choice and you will see the ISE. Thanks!
Cheers
JK
Element SELECTION is undefined in FORM.
The error occurred in D:\securecontent\cced\choice.cfm: line 9
7 :
8 : <body>
9 : <CFOUTPUT>IN HERE #form.selection#</CFOUTPUT>
10 : <CFIF #form.selection# IS "one">
11 : <CFLOCATION URL="registern.cfm">
Resources:
Check the ColdFusion documentation to verify that you are using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1; .NET CLR 1.1.4322; .NET CLR 2.0.50727; InfoPath.1)
Remote Address 24.59.145.155
Referrer
Date/Time 09-Apr-07 05:13 PM
Stack Trace (click to expand)
at cfchoice2ecfm2114110539.runPage(D:\securecontent\cced\choice.cfm:9)
coldfusion.runtime.UndefinedElementException: Element SELECTION is undefined in FORM.
at coldfusion.runtime.CfJspPage.resolveCanonicalName(CfJspPage.java:1061)
at coldfusion.runtime.CfJspPage._resolve(CfJspPage.java:1038)
at coldfusion.runtime.CfJspPage._resolveAndAutoscalarize(CfJspPage.java:1137)
at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:152)
at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:349)
at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:210)
at coldfusion.filter.PathFilter.invoke(PathFilter.java:86)
at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:69)
at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28)
at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
at coldfusion.filter.RequestThrottleFilter.invoke(RequestThrottleFilter.java:115)
at coldfusion.CfmServlet.service(CfmServlet.java:107)
at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:78)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91)
at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:257)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:541)
at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:204)
at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:318)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:426)
at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:264)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
What happens when you do this?
<cfdump var="#form#">
<cfabort>
struct
FIELDNAMES SELECTION
SELECTION 1
Are we talking about the choice of "Quick Links"? Is that supposed to
be an option? If it is, it does thrown an error when I select it, but
looking at the url it does not seem to be complete?
"https://www.mvcc.edu/cced/Quick%20Links"
The other links in the drop down took me to standard links ending in
file extensions like .cfm and .pdf.
My bad, the URL is https://www.mvcc.edu/secure/cced/index.cfm
JeffK wrote:
> My bad, the URL is https://www.mvcc/edu/secure/cced/index.cfm
You may be having a more basic server configuration issue. That URL did
not work for me either. I got a "Server not found Firefox can't find
the server at www.mvcc" error.
Ok, fixing the url to "https://www.mvcc.edu/secure/cced/index.cfm"
brought up a page.
I'm getting a DATASOURCE not defined error, not a page not found error.
Have you migrated all the data sources from the old server to the new
one? Did you change the names along the way?
"Data source cced could not be found.
The error occurred in D:\securecontent\cced\registern.cfm: line 13
11 : <cfset getDate=#DateFormat(now(), "mm/dd/yy")#>
12 :
13 : <CFQUERY name="desc" datasource="cced">
14 : SELECT *
15 : FROM registration"
Documentation
