Hi guys.
Getting an error on a Win 7 machine trying to open help (she has IE10). It gives the following error:
"Object doesn't support property or method 'request'" and then the URL points to the whproxy.js file. It asks if we want to continuing running scripts, but won't accept either a yes or a no.
This does not seem to be an IE10 issue - I have another machine on Win 8/IE 10 that opens fine. AND I have a computer with Win 7 and IE10 that opens fine, too.
The WEIRDEST thing about this is the message refers to "Line 137, Char 17." But my "welcome" topic on the project is a simple one with only 26 lines of HTML code!
Any ideas?
Chris
The line numbers refer to a line in whproxy.js, not the topic.
My guess would be that it is a security setting. Do you have this issue when the help is located locally or also when it is placed on a webserver?
Greet,
Willam
Willam,
I copied the project onto her hard drive and she is able to open it locally. But I'm not sure what that means?
Chris
A recap to make sure I understand the situation:
Am I correct? In this case, it seems that Internet Explorer has an issue with the scripts in the intranet environment. Can you check the security settings? (See http://support.microsoft.com/kb/174360)
Greet,
Willam
