You got it. All work must be done locally. That means your
options are:
- The whole project is on one local drive and one person
works on it.
- You create a merged help file which is actually a number of
projects where the outputs are merged at runtime. That means
different people can work on different areas. It requires some
careful management.
- You put the project into source control and then each
author pulls out what they want to work on.
The reason working otherways off a network will fail is, as I
explained, the Access database. Your network person may be aware
they are an issue but nothing they can do about it.
