Why do I see all these messages in coldfusion-error.log? There are tons of them. This is CF10/Win2008/IIS7.5. Single server, medium site, pretty typical set up.
Nov 07, 2013 11:10:14 PM org.apache.tomcat.util.http.Cookies processCookieHeader
INFO: Cookies: Unknown Special Cookie
Nov 07, 2013 11:10:37 PM org.apache.tomcat.util.http.Cookies processCookieHeader
Nov 07, 2013 11:11:13 PM org.apache.tomcat.util.http.Cookies processCookieHeader
Nov 07, 2013 11:11:17 PM org.apache.tomcat.util.http.Cookies processCookieHeader
Nov 07, 2013 11:11:26 PM org.apache.tomcat.util.http.Cookies processCookieHeader
Nov 07, 2013 11:12:31 PM org.apache.tomcat.util.http.Cookies processCookieHeader
And so on.....
This is a known Tomcat issue. To stop the warnings, go to \cfusion\runtime\conf\logging.properties.Set org.apache.catalina.core.ContainerBase.[Catalina].[localhost].level to WARN and then restart CF.
Okay, good to know! It would have been nice if this was fixed in the last round of updates. I will make the change in logging soon. Thank you.
Hi, again. I did that but I'm still getting some of those errors in my log (yes, I restarted the server). Here are other areas of that logging.properties file, and I wonder if the other values need to be changed from INFO to WARN as well?
# Facility specific properties.
# Provides extra control for each logger.
org.apache.catalina.core.ContainerBase.[Catalina].[localhost].level = WARN (this is the one I changed)
org.apache.catalina.core.ContainerBase.[Catalina].[localhost].handlers = 2localhost.org.apache.juli.FileHandler
org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/manager].level = INFO (what about this?)
org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/manager].handlers = 3manager.org.apache.juli.FileHandler
org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/host-manager].level = INFO (and this?)
org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/host-manager].handlers = 4host-manager.org.apache.juli.FileHandler
Change 'em all. I did
Hi, again. I've changed them all, and rebooted my server several times since, and I'm still getting these annoying messages in the log. This is in the logging.properties file under c:\coldfusion10\cfusion\runtime\conf
org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/manager].level = WARN
org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/host-manager].level = WARN
But in my coldfusion-error-1.log I'm still seeing this as of today. Is there anywhere else I should look to change the setting??
Nov 25, 2013 11:46:25 AM org.apache.tomcat.util.http.Cookies processCookieHeader
Nov 25, 2013 12:01:34 PM org.apache.tomcat.util.http.Cookies processCookieHeader
Nov 25, 2013 4:42:48 PM org.apache.tomcat.util.http.Cookies processCookieHeader
INFO: Cookies: Invalid cookie. Value not a token or quoted value
Nov 25, 2013 4:42:53 PM org.apache.tomcat.util.http.Cookies processCookieHeader
Nov 25, 2013 4:42:57 PM org.apache.tomcat.util.http.Cookies processCookieHeader
Nov 25, 2013 4:43:03 PM org.apache.tomcat.util.http.Cookies processCookieHeader
Nov 25, 2013 4:43:21 PM org.apache.tomcat.util.http.Cookies processCookieHeader
I recallI that I had three logging.properties files. Edit each and also look for a section called "Default global logging level" and ensure that this has ".level= SEVERE". The logging.properties files that I have are in c:\ColdFusion10\cfusion\runtime\conf\, c:\ColdFusion10\cfusion\jetty\jre\lib and c:\ColdFusion10\cfusion\jnbridge\jre\lib. If this doesn't work for you it may be best to email Adobe install support on cfinstal@adobe.com.
So I did that I think it finally helped with that specific log issue. HOWEVER, by changing those log settings everywhere it prevented critical tiools like Jconsole and Jprofiler from running, so just FYI.
