Can I manually change the time/duration of each diapo ?
Yes, each slide's duration it tied to the audio or silence that is associated with it. Open the audio editor and you can either remove audio/silence or add silence to it. Audio can also be recorded here, but it is better done through the record audio dialog as it will provide the ability to have a script for it, from the notes section of PPT for that slide.
I believe that with Presenter 8+, the slides have a minimum display time of 1 second.
Thank You !!!!!!!!! It's working !
