I have only two images - one comes out fine and the other is red. Changed the image and the second is also red!!! AHGGHGHGHGHGH!
Increase slide quality to 24 bit on those affected slides.
Default slide quality in CP7 is Optimized, would changing that to High really solve the red images? I used to have them only when slide quality was Low.
I'm experiencing the same problem, in 2 x separate projects, i've tried all sorts of fixes, differernt image types, resampling image, changing slide quality. No luck. Just seems to pick images at random.
I think I solved it - it's a memory issue and when I opened and closes Captivate a few times (weird work-around), it compresses the slides enough so that they all come up OK. It doesn't help the image quality, but, for this project, that wasn't as important as getting rid of the RSoD.
I had the same problem.
Chances are your images are too large for Captivate to handle. Try opening them in Photoshop or any photo editor and resize them to something much smaller.
In my case down to 1MB worked fine and the image quality was still very good.
I tried this, but it didn't work completely. In retrospect, when I do a project with multiple images, I would use another medium - like iMovie. Thanks for responding.
Thank you for all the suggestions. I tried resizing it and that helped a little, but the thing that helped more was to open and close the project - and Captivate - several times. Captivate compresses its contents each time. The other thing I did was to put some of the images on a PPT and import that. This cut down on the number of images I had to import into captivate.
