Emmim44:
> so Do you have any clue or not ?
I'm a beginner in PL/SQL but brushed up to be able to offer
assistance. I gathered this much. One must use a cursor variable to
return the result set of a PL/SQL stored procedure. Thus you
defined a REF CURSOR ref_cur_type in a PL/SQL package called
your_pkg. Your stored procedure, your_proc, executes a
select-query. The procedure's input is the numeric variable in_id.
Its output, the ref_cur_type variable out_rec, is what we expect
the procedure to return to Coldfusion. It contains the result set
comprising the rows from the table bpar whose un value is in_id.
Did I miss something?
Emmim44:
> He [BKBK] thinks he knows too much :P..but he couldnt
figure out why is not working..
You are right, Emmim44. I haven't figured out why it is not
working. Neither have you. We're all in the search together, and
the main person to benefit is you. Don't rage against me, rage
against yourself or against the machine.
Paross1:
> BKBK, this looks like a sample PL/SQL package and stored
procedure that I posted a
> while back in response to an earlier question, so he
probably just used the names that
> I had used in in the example.
Thanks, Paross1, for the information. I don't use Oracle,
hence my question comes from ignorance. Is the naming convention
package_name.procedure_name transparent to Coldfusion?
