Hi all,
for generating an uncompressed Java help with search function I need to configure the JDK path in the settings of the SSL. I have jdk1.7.0_45 installed but when I select the correct folder then simply nothing happens and the SSL settings are displayed again. To verify, if I select a different folder then RH displays an error message because the required files were not found. So evidently RH does find and recognize the JDK, but fails to generate the output.
This in Win7 64bit, has anybody succeeded in setting up RH in this environment for java help?
Robert
Have something to add?
