Hi All
I do lots of multicam concerts, and don't have genlock or timeslave on my cameras. Therefore the audio in my multicam sequences is often out of sync by a fraction of a frame. About half the time, this creates a noticeable "phase" effect when I mix audio from two or more cameras. Is there a way I can nudge the timing of the audio on one track by a fraction of a frame, in order to eliminate the effect? A similar phenomenon occurs on audio from a single camera, when the audio is coming through different sources (e.g. A1 from a wireless on stage, passing through a mixer, alongside A2 from a shotgun, wired straight into the camera). I'd really like to pull this off without a round-trip to Audition. (I am using
PrPro CS6 on Win7)
Eric D - CoralVision
If you check Show Audio Time Units in the sequence flyout menu, you will be able to nudge audio clips at the sample level.
