Hi Bill
First off, I'm pleased Cindy's issue was resolved. However,
what you explained as the reason doesn't seem to match my
understanding of RoboHelp. So naturally I have questions.
You said:
These files will start with the letters "rlt" and are created by
the system whenever you edit a file that is flagged as read
only.
Now I've always understood that these little beasties only
get created when you
preview a topic. I do know that it's not uncommon to find
them lurking about among your true project files. I've always
assumed that something happened that caused RoboHelp not to be able
to clean up after itself, leaving these orphan files behind. I've
also always advised students that these files are totally safe to
blow away, as they are simply temporary files created and used
during the process of previewing.
So I performed a little test. I used a small test project and
flagged one of my topic files as read only. I then tried to edit
the file. It opened just dandy in the WYSIWYG editor. But when I
tried to edit, I received a message advising the file was read only
and asking if I really intended to edit. After saying yes, the read
only flag was removed and the edit happened just fine. During this
whole process, I monitored the folder location and never saw the
rlt file appear.
I then tested my preview theory. I previewed the topic and
flipped over to Windows Explorer and sure enough, there was my
little additional rlt file.
Now here's the kicker. I was trying to duplicate what Cindy
reported. But regardless of how I try to induce it, I'm not able
to. Because RoboHelp normally removes the rlt file after you close
the preview, I sneaked behind RoboHelp's back and flagged the rlt
as read only. This way RoboHelp couldn't delete it and clean up. I
then closed the preview. Compiled and tested and no duplicate Index
entries. I also examined the compiled .CHM for the existence of any
file beginning with rlt. Again, nothing.
Needless to say, I'm more than a bit confused at this point.
Cheers... Rick
