Hi All,
Here is my problem,
I have a user defined function, which will give me the output as " table.column = <cfqueryparam cfsqltype = 'cf_sql_varchar' value = 'test'>;
but when i pass this as my where clause in the query.
I always get missing experssion (00936) error.
When I ON the debug information in CF, I copied the query its running;
any help would be highly appreciated.
I have tried replacing this double quotes with single quotes using Rereplace and replace function; tried preservesinglequotes(); all are returning the same error.. May be I'm missing something.
THe below is the query formed; and its the one I get when I on the debug information (sql)
SELECT * FROM SHOP_FINDINGS WHERE ROWNUM<=20 AND (OPER_NAME = <cfqueryparam cfsqltype='CF_SQL_VARCHAR' value='IN STOCK'> )
I m using CF 9 and Apache server.
59 views No reply.:(
I need some help ..
<cfqueryparam> is normally used when you want to sanitize user input (URL or Form scope data etc) that is passed to a database query. In this case the string "IN STOCK" is hard-coded, so why not just use:
WHERE ROWNUM<=20 AND OPER_NAME = 'IN STOCK'
Does that SELECT statement work? Also, try specifying the column names in the SELECT, rather than using the * wildcard. The parentheses are not needed in your statement either I don't think. This error normally occurs when you specify a missing column name or wildcard, or if a bracket/comma is missing or doesn't match etc. Re-check the query and write a test template to just issue one query to test it perhaps.
Hi Tribute,
Thanks!!
FOr an example, I made the value as "In Stock" but actually it was the user input.
selecting the columns dint work:(
Yes I m using the test template only; i have made the function and query separately and trying it but still in vain.
Can you please post your code in its entirety? Please also try using "cf_sql_char" as the sql type and give that a shot. Also, try omitting the cfsqltype and see what error, if any, that gives.
