CF 10 installed fine and CFIDE/Admin ran ok, however, other sites did not invoke CF10 even though 'all' was specified in the install and all IIS options were enabled. Used the connector to remove the 'all' entry, but now cannot add it back. What's the fix?
Perhaps run \ColdFusion10\cfusion\runtime\bin\wsconfig.exe as administrator.
HTH, Carl.
Check in IIS if each site has a CFIDE and jakarta virtual directory. Also, click on them and check to see whether they have handlers for the ColdFusion filetypes. I've had installs go sideways (and each time the Admin installed fine), but then noticed that (usually the vdirs) did not exist, and after creating them, everything was fine at that point.
IIS has all requirements installed now. Can delete and add connector to 'All', but only CFIDE and root website parse cfm. Added virtual directories to a site and it still doesn't parse cfm files - receive 'Internet Explorer cannot display the webpage' error. Verified that those sub directories all have proper handlers inherited.
If this is not a production server, then try reinstalling ColdFusion 10 with Admin rights
