Show 2 replies
1. Re: Issues with "crop" effect; GPU accel
JSS1138 Nov 23, 2013 7:39 PM (in response to wannabemekon)I'm not seeing that here with my 560 Ti using the 331.65 driver.
What happens if you remove the CC and just leave the Crop?
2. Re: Issues with "crop" effect; GPU accel
wannabemekon Nov 23, 2013 9:55 PM (in response to JSS1138)If I remove CC the line remains.
But: I figured out the cause, or rather the suspect effect. There was also a motion effect applied --change in scale and position over time. If I turn the motion effects off on each clip, the line disappears.
Blown up to 400 percent the line appears one pixel wide with a one pixel line on either side that seems to be the same color but at about 50 percent of the central line's brightness.
