Nothing wrong with the question except the title. Helps if
they are titles that others will search for.
You have two main options. One is generate a CHM instead so
that he can see the content but of course that will not have the
skin. So if that is important, then zip up everything that is in
the webhelp folder under !SSL! assuming you generated to the
default location. You need to send all that is in that folder and
its sub folders, assuming you want the webhelp to work. :-)
