Show 3 replies
1. Re: Temporarily disable hover scrub?
JSS1138 Nov 23, 2013 8:33 PM (in response to Elliott B.)If you click on the gray underneath the clip (where the clip name is), it will open on the first frame.
2. Re: Temporarily disable hover scrub?
Elliott B. Nov 24, 2013 10:10 AM (in response to JSS1138)Thanks. Clicking the gray space actually prompts you to import new files, but I figured out you meant to click the file name. That works sometimes (about 80% of the time). But the filename is such a small target to hit, that it might just be faster to click the thumbnail then hit the up arrow.
3. Re: Temporarily disable hover scrub?
JSS1138 Nov 24, 2013 4:23 PM (in response to Elliott B.)You can click in between the file name and duration as well.
