How do I deploy the project into my weblogic Application Server? Should it be fine if I copy the project folder to the AS root?
Also, How should i invoke the Context sensitive help from Javascript assuming project deployed to Weblogic AS.
I am using Robohelp 10.
Thanks in advance.
You generate the help and then you copy the generated output to the server.
For context sensitivity, which output are you using? Try the following
pages for more info:
http://www.grainge.org/pages/authoring/calling_webhelp/calling_webhelp.htm
http://www.wvanweelden.eu/article-category/context-sensitivity
Greet,
Willam
Greet,
Willam
Good Day William,
Thanks a lot . This helped . I am using Web Help as the output.
Please suggest if Web Help is to be used or Web Help Pro.
Also, I have copied only the WebHelp Folder generated and not the entire Project Folder generated by the RoboHelp.
Sdesab
