Ted,
Thanks for your reply. There is good and bad news here.
Following through all the links from the one you sent me, I
downloaded a file, dstDates.cfm (technote d2ab4470), which I
installed and ran on both my production and development servers. On
my production server, I saw that the dst changes had not been made,
but I did get the correct time zones (cst, cdt, etc.) in the
correct places for a system that has not been updated. When I ran
it on my development system, all of the time zones said GMT!!! And
they were showing the time as GMT time.
Both systems are running the default MX jre
(C:/CFusion/runtime/jre) and have the same JVM, 1.4.2-b28, which is
shown in the dstTest results.
I downloaded the JVM update, 1.4.2_11, and installed it. I
then went into CF Admin and pointed CF to the new JVM location. I
did this with some concern that the JVM Arguments would not be
correct. This concern was not unfounded. CF would not start. I
restored the original java.config file and CF started again.
So I'm left knowing that my development server returns GMT
times instead of local times on my development server and that my
production server does not return the correct local time for
several weeks during the year. Until I can get the new JVM to run
correctly on my development server, I'm not going to try to install
the new JVM on my production server.
I've pasted in the results of the dstTest into the code
window.
Do you have any suggestions at this point???
Thank you for your help so far.
Len
