I just updated my OS to Mavericks & now I cant use my CS6 or CC AE ap.
When I run the patch I get the error 'UPDATES COULD NOT BE APPLIED' & it says Updates have been supressed by the admin.
How do I install this update?
My IT dude has no clue & is offering me no support.
Thanks in adveance.
Please try below steps & let us know if it works.
Ashish
tried it & this what I got....
rm: /Library/Application: No such file or directory
rm: Support/Adobe/AAMUpdaterInventory/1.0/AdobeUpdaterAdminPrefs.dat: No such file or directory"
hmmmmm....
any ideas?
thanks in advance.
Still no luck getting the 12.1 Patch to install....day number five trouble shooting.
Here is what I have tried...
I am now looking for ways to get AE CS6 installed because I have a ton of projects dues mid week.
Thanks for the help on this problem. I am so baffeled.
I had exactly the same issue and followed the same steps as you did with the same results.
I manually followed the path indicated above and deleted the "AdobeUpdaterAdminPrefs.dat" file and then the installer launched successfully.
Manually following the path
/Library/Application Support/Adobe/AAMUpdaterInventory/1.0/AdobeUpdaterAdminPrefs.dat
And deleting that .dat file did it for me.
I then started up a CC program and looked under the help menu on the Nav bar at the the top (mac). Clicked the update link and things started happening. Finally!
