1. Re: Default rotate to object group center not artboard center
tman69 Nov 27, 2013 8:54 PM (in response to MooseDesign)it is mind numbing--but NOT obvious--IF you use the 'transform pallette' the rotation occurs based on which point you have selected (center, upper left, lower left, etc--see capture1) if you use the menu from the menu bar at the top of the UI--the rotation is 'always' from the center of the group--see capture 2
2. Re: Default rotate to object group center not artboard center
Jacob Bugge Nov 28, 2013 12:58 AM (in response to MooseDesign)rcbmoose,
As I (mis)understand it (differently from tman), it sounds like a corruption or something (hopefully not a bug, which should have been detected earlier, I believe).
Unless solved otherwise, you may try the following (you may have tried/done some of them already) and see whether it helps (the following is a general list of things you may try when the issue is not in a specific file; 3) and 4) are specifically aimed at possibly corrupt preferences):
1) Close down Illy and open again;
2) Restart the computer (you may do that up to 3 times);
3) Close down Illy and press Ctrl+Alt+Shift/Cmd+Option+Shift during startup (easy but irreversible);
4) Move the folder Other options (follow the link with that name) with Illy closed (more tedious but also more thorough and reversible);
5) Look through and try out the relevant among the Other options (follow the link with that name, Item 7) is a list of usual suspects among other applications that may disturb and confuse Illy, Item 15) applies to CC, CS6, and maybe CS5);
Even more seriously, you may:
6) Uninstall, run the Cleaner Tool (if you have CS3/CS4/CS5/CS6/CC), and reinstall.
