long process on shared server?
Apr 15, 2007 Apr 15, 2007
I built an application that has 2 scheduled tasks. One of them sends
e-mails to a list on a daily basis and the other completes an HTTP
request.
The number of records is getting larger and these tasks are failing
because they exceed the timeout set on the ColdFusion or web server.
I'm using a shared hosting environment at Network Solutions and it's
unlikely I'd be able to increase the timeout.
This application is built using ColdFusion Components.
I had heard of a asynchronous gateway I might be able to use, but
again, I don't know if I'd be able to set that up on a shared hosting
environment.
Does anyone have any ideas, aside from getting a dedicated server?
I thought about maybe instead of performing all these requests in a
single page call, but instead, scheduling each request a few seconds
from each other, but I don't know if CFSCHEDULE will allow hundreds of
entries at a time.
Andy
Advanced techniques
290
> environment.
the asynch gateway should be cheaper than a dedicated server. i'd start w/that
first. it works very well.
I do not know how this plays in shared hosting environment so use with
extreme caution. But you can use the <cfsetting requesttimeout=""> tag
at the beginning of a page to specify how long that page has to run,
somewhat overriding the setting given in the administrator. But I could
see hosting companies controlling this tag for what it could do to the
performance of their servers if misused.
Async gateways are a good option if they are available to you. They do
require the 'enterprise' level of CF. Gateways are not included in the
'standard' edition. They also require some CF-Administrator
configuration, but nothing more then a scheduled task or DSN
configuration does.
How can I use the asynch gateway on a shared hosting environment?
Can I set it up without having access to the ColdFusion Administrator?
ask your host to set one up (provided, as ian says, they have enterprise).
nope.
Documentation
