I tried the following for Remote Services:
MXML File:
<?xml version="1.0" encoding="utf-8"?>
<mx:Application xmlns:mx="
http://www.adobe.com/2006/mxml" layout="vertical" cornerRadius="2"
backgroundGradientColors="[#b0bdf7, #b0bdf7]">
<mx:RemoteObject id="c4cast" destination="c4cast"
fault="handleError(event)">
<mx:method name="getUser" result="handleUserLogin(event)"
</mx:RemoteObject>
<mx:RemoteObject id="test" destination="test"
<mx:method name="getUsers"
result="handleUserLogin(event)" />
</mx:RemoteObject>
<mx:Script>
<![CDATA[
import mx.rpc.events.ResultEvent;
import mx.events.ListEvent;
import flash.events.MouseEvent;
import mx.controls.Alert;
import mx.rpc.events.FaultEvent;
import mx.collections.ArrayCollection;
//import com.cognizant.c4cast.*;
import com.test.*;
[Bindable]
public var loggedInUser:TestUser = null;
var userCollection:Array = null;
public function handleError(event:FaultEvent):void{
Alert.show("Error during Remote to C4CastService
:"+event.toString());
public function handleUserLogin(event:ResultEvent):void
var res:ArrayCollection = event.result as ArrayCollection;
Alert.show(""+res.length);
if(res.length >= 1){
loggedInUser = res[0];
Alert.show(""+loggedInUser.applications[0]);
//loginSuccess();
}else{
Alert.show("Login Failed !!!["+res.length+"]");
public function loginSuccess(){
this.logOut.label = "Log Out";
mainView.visible = true;
this.useridLabel.visible = false;
this.pwdLabel.visible = false;
this.userid.visible = false;
this.password.visible = false;
private function logInHandler (event:MouseEvent):void
this.test.getUsers.send();
private function selectionChanged (event:ListEvent):void
var selectedItem = appList.selectedLabel;
AppLabel.text = "Application Chosen is: '"+selectedItem+"'";
</mx:Script>
<mx:ApplicationControlBar dock="true"
creationComplete="this.test.getUsers.send()">
<mx:Label
text="See-4-Cast"
fontFamily="Verdana" fontWeight="bold" fontSize="12"
<mx:Spacer width="100%" id="spacer01"/>
<mx:Text id="useridLabel" text="User Id:"
textAlign="right" fontWeight="bold"/>
<mx:TextInput width="98" id="userid" maxChars="10"
text="anandbn"/>
<mx:Text id="pwdLabel" text="Password:" textAlign="right"
fontWeight="bold"/>
<mx:TextInput width="98" id="password" maxChars="10"
displayAsPassword="true" text="password"/>
<mx:Spacer width="100%" id="spacer02"/>
<mx:Button label="Log In" id="logOut"
labelPlacement="right"
enabled="true" click="logInHandler(event)"/>
</mx:ApplicationControlBar>
<mx:ViewStack id="mainView" width="688" height="334"
visible="false">
<mx:TabNavigator x="10" y="10" width="100%"
height="100%">
<mx:Canvas label="Forecast Info" width="100%"
height="100%">
<mx:Label x="30" y="32" text="Choose Application:"
width="119"/>
<mx:ComboBox id="appList" enabled="true"
left="157" top="30" change="selectionChanged(event)"
selectedIndex="0">
</mx:ComboBox>
<mx:Label id="AppLabel" x="30" y="74" text="Application
Chosen is:" width="351" height="144"/>
<mx:Button x="340" y="30" label="Refresh"/>
</mx:Canvas>
<mx:Canvas label="Contractor Hours" width="100%"
height="100%">
</mx:Canvas>
</mx:TabNavigator>
</mx:ViewStack>
</mx:Application>
AS Object definitionspackage com.test
[Managed]
[RemoteClass(alias="com.flex.test.model.TestUser")]
public class TestUser
public var name:String;
public var applications:ArrayCollection;
package com.test
[Managed]
[RemoteClass(alias="com.flex.test.model.TestApplication")]
public class TestApplication
Java Object definitions:public class TestUser {
private String name;
private List<TestApplication> applications = new
ArrayList<TestApplication>();
public class TestApplication {
Issue Description:
The type of object I'm expecting is TestApplication but it
shows up as "object Object". I am not sure why the object in the
List is not getting converted to the correspong AS Object.
