I am running Windows 7 with the latest updates assuming they downloaded and installed correctly. I use Internet Explorer 10. I have to install Flash Player every time I start up my PC. It runs fine until I shutdown and then when I start up again I have to install Flash Player all over again. I sure hope someone can help me.
Try it from a fresh start:
Download the following files by right clicking and selecting "Save target as".
Flash Player for ActiveX (Internet Explorer)
Save ALL files to your Downloads folder - DO NOT RUN anything yet.
Reboot your system.
BEFORE opening anything else, go to your Downloads folder and run the UNINSTALLERS to remove the Flash Player and Shockwave plugins.
Go to: C/Windows/System32.
If there's a Macromed folder there, delete it.
Go to: C/Windows/SysWOW64.
Open your Registry Editor (Start>Run or press the Windows key+R and type "regedit", then click OK)
Under HKEY_LOCAL_MACHINE/SOFTWARE delete the Macromedia folder.(If it's there)
Under HKEY_CURRENT_USER/Software delete the Macromedia folder. (If it's there)
Close the Registry Editor.
Next, run the ActiveX Installer.
Then go to: http://get.adobe.com/shockwave/otherversions/ and download &install the Shockwave FULL installer for Windows (Internet Explorer)
Once it's installed, see:Enabling Flash Player in Internet Explorer and: ActiveX Filtering in Internet Explorer to make 100% sure that Flash Player is enabled and NOT being blocked by ActiveX controls.
WOW, this is a very detailed response, thank you. Everything went just fine until I ran into trouble deleting the Macromed from C/Windows/SyWOW64. It refuses to delete because of a file mms.cfg until it has admin approval. I am supposedly logged in as the Admin. How do I get rid of that file?
There's almost NOTHING it won't delete.
You are outstanding and very generous to take time to help me. From what I can tell the problems are solved. Even this old man could follow your instructions, well done. Buy yourself a sody pop on me. LOL
Thanks again
Darrel
