I was wondering if you can add a property/code to the skin that would stop horizontal scrolling of the TOC/hide the horizontal scrollbar. I've tried a few things but none of them seem to work.
What output are we talking about?
And which methods did you try?
Kind regards,
Willam
Webhelp and a CHM help project
I don't know if that can be done in CHM, but perhaps a CHM guru can
confirm that.
As for WebHelp, there is no way to get this done consistently as not all
browsers support disabling scrolling in a frame. You must add
scrolling="no" to the navpane frame which is inserted with JavaScript on
whskin_frmset01.htm.
Kind regards,
Willam
If you have RH10 you could try using Willam method in conjunction with the WebHelp to CHM Converter extend script.
As long as you keep in mind that the no scrolling is only supported in
IE8 and lower. So most users will be out of luck. (CHM uses IE under water.)
Kind regards,
Willam
