1. Re: Hiding a set of triggers
aishvarya rastogi Dec 6, 2013 1:12 PM (in response to sebrame)Hi,
Correct me if I am wrong. You are using thumbnail inside the tooltip. To make the active target visible until another trigger is clicked, please select "Show target = onclick and Hide target = On click" for the tooltip settings. Keep the thumbnail settings as it is.
Hope this helps.
Cheers!
Aish
2. Re: Hiding a set of triggers
sebrame Dec 6, 2013 1:38 PM (in response to aishvarya rastogi)Correct. Each 'Category' button on the left triggers a Tooltip containing the image buttons. If I do as you say, and set Hide target = On click, then each Tooltip stays open until it's 'Category' button is clicked. Since the Tooltips are stacked on top of each other, if one is underneath another, it won't show until the upper Tooltip's Category button is clicked, which can get confusing if more than one Tooltip is open.
What I need to do is have an open Tooltip close whenever another Category button is clicked, allowing that Category's Tooltip to be shown. This is possible in other WYSIWYG web authoroing programs, such as Serif's Webplus. Hopefully it can be added to Muse in a future release.
3. Re: Hiding a set of triggers
aishvarya rastogi Dec 6, 2013 2:04 PM (in response to sebrame)Hi,
The tooltip doesn't stay open in you click another tooltip when using Hide Trigger = On Click. Please refer to the following screencast : http://screencasteu.worldsecuresystems.com/aish/2013-12-07_0332.swf
Please let me know if I am missing anything.
Aish
