Show 3 replies
1. Re: What causes projects to be corrupted?
Mark Mapes Dec 7, 2013 10:56 PM (in response to Elliott B.)This sounds a lot like what's discussed here: http://forums.adobe.com/message/5837375#5837375.
If you're hitting the same problem, then two things to note:
- noarprodz posts a way to fix the project in Post #6
- The issue discussed there has been resolved in the version we're currently working on.
2. Re: What causes projects to be corrupted?
Elliott B. Dec 10, 2013 3:01 PM (in response to Mark Mapes)It does indeed sound like the same issue. Looking forward to the update. In the meantime, can you confirm that noarprodz' method of deleting all those errant lines in the XML doesn't harm the project at all?
3. Re: What causes projects to be corrupted?
Brett_Kosmider Dec 10, 2013 3:26 PM (in response to Mark Mapes)So when is the new release due to come out? Also, (unreleated) will SG fix the matte problem? Both of these issues are making Adobe a no-go for professional editing situations.
