1. Re: How to remove splotches of color?
c.pfaffenbichler Dec 8, 2013 9:04 AM (in response to pansylou) -
2. Re: How to remove splotches of color?
pansylou Dec 9, 2013 3:58 PM (in response to c.pfaffenbichler)I am trying to do as you ask, but it is a PSD file and I don't seem to be able to upload it because it is too big. I am trying to just upload one layer that shows a shirt, but it won't let me change it to a jpeg. I will try to upload the original jpeg and see if that works.
3. Re: How to remove splotches of color?
gener7 Dec 9, 2013 4:23 PM (in response to pansylou)You can use File > Save for Web on the psd and it will create a separate jpeg of your image.
5. Re: How to remove splotches of color?
gener7 Dec 10, 2013 2:10 PM (in response to pansylou)I was just giving help for posting your picture as a jpeg,I'm not familiar with color correction. I'll bump this so others can give you the best advice.
Gene
6. Re: How to remove splotches of color?
jgrummel Dec 11, 2013 7:32 AM (in response to pansylou)Try using the Color Replacement Brush!
Here's how:
Use the Eye Dropper Tool to select the color you want the yellow spots to be:
This is the color I sampled:
Then, choose the Color Replacement Tool hidden behind the brush tool:
Then, using a large radius brush, brush over the areas you want to correct:
hope this helps!
Julia -
7. Re: How to remove splotches of color?
gener7 Dec 10, 2013 3:45 PM (in response to jgrummel)I know it does for me!
